Help! my Northgate keyboard is acting weird!
Matt L
395
I've had a Northgate Omnikey Evolution Keyboard for some time, since I read about it here. It's been great but yesterday the middle row of key started acting up. the "a" is now a space, "s" and "L" are "a", and the rest of the middle row seems to be shifted by one letter. What happened? Can I fix it?
I thought I might have a virus, and did, but the keyboard does the same thing on any of my other computers, so it's hardware. I did a search and found the keyboard going for $200.00 now so replacing it is not an option. Love the feel and the layout, I really want to keep the keyboard.
skriefal
1,424
You could try holding down the ESC key while booting the computer. That'll reset the keyboard programming/mapping on some of the Northgate keyboards. Some of the others can be reset by hitting the Ctrl-Alt-Suspend Macro keypress sequence. If neither of those work, then a lengthy search via Google Groups is recommended...
trikster2
Banned
Oct 28, 2000
1,907
You could try washing it.
My northgate was giving my wife a lot of problems, she gave it a good soaking in the sink and everything worked well for another few years.
It's sitting in the garage now, a little loud for the family room, but great keyboard. Wish they still made them like that (for a reasonable price).
Matt L
395
Thanks skriefal, The ESC while booting did the trick! Don't know why, I've never done any thing with mapping, but I wonder if it was the side effect of the Exploit-MIME.gen.b virus that I found on my system last night.
Thanks again.....
