I have recently started having a problem with my beloved Logitech Z-680's. I game quite a bit and have used my Headphone jack on the 'Pod' quite often when the Wife and kids are home. About a month ago, after unplugging my Headphones then sound would not resume coming out from the speakers. I plugged the headphones back in and they worked fine, unplugged them and no sound. A littel bit later the sound came on from the speakers and when it did it 'ramped up' in volume like the sound didn't come blasting out, but instead started a bit lower then the 'normal' volume and then got progressively louder until it was where the volume dial was set.
This happened 2 or 3 times and once it seemed that picking up and shaking/tapping the 'Pod' helped it return. Since then I stopped using my headphones and all worked fine for weeks. Then yesterday I used my headphones again and now I have no sound. It did come back on and then went off about 1 hour later, again going from soft to normal.
I have used my headphones about 2 or 3 times today when I played a few rounds of BF2 and all is fine with them. I have tried 'blowing' into the 1/8" mini jack hoping that a bit of dust was keeping some connection stuck 'closed'. I have also tried tapping/shaking/banging the 'Pod' in hopes that the problem would go away. When that didn't help I tried shaking the sub-woofer cabinet hoping that it would help. No luck.
Has anyone else had this problem? I had ordered these speakers on "July 23, 2004" and have been VERY happy with them until this started. I have tried playing with the 'mute' button and the 'input' button, but nothing helped.
perhaps there is a little micro-switch that gets tripped when the 1/8" mini jack is used and it is just binding? Any help would be GREATLY appreciated. I really don't want to replace these speakers yet.
-Thanks, Ken
-Thanks, Ken
