Help my friend put together a $300 system
Madcowz
2,652
Yea I know you can't get much with $300, but it's a start... Plus anything you get with $300 oughta be better than his Pentium 200 MMX w/ 32MB EDO RAM. I'm thinking about a barebones system from Compgeeks and a Celeron... something along those lines. Anyone have any other suggestions?
mjquilly
1,692
Go with a Duron instead, cheaper and more performance than the celery...and you're right, you can't get much w/ $300. The good thing about the Celeron is that you can get a Mobo w/ integrated video, sound and nic/modem, if you consider that a good thing which I do not. That would easily offset the price difference between Duron/Celeron. So I guess I change my mind, go celery to keep it as low as possible.
BigLance
1,206
Does his sytem need everything (like Hard drive(s), video, sound etc?) If so, here is my best:
Thes prices do not include shiiping costs...
AMD Duron 650MHz $43
FIC AZ11 Duron 133MHz FSB 3D Video Motherboard $88 Can be upraded later on with faster video board....
ZEUS 128MB PC133 SDRAM $43
Creative SB PCI128 $23
15GB Quantum UDMA/66 Hard Drive $91
Delta 52X CD-ROM $26
3Com USR 56k v.90 Winmodem PCI $26
Mid Tower Genica ATX Case $17
Thats about it cept monitor, comes out to $357. That is over his limit but maybe you don't need all that hardware..
www.pricewatch.com is where I pulled the information
Good Luck !
Instigator
375
Your only real hope is an E Machine. $300 is not alot to work with if you want something that is new. If you don't mind signing up for a 3-year subscription to Compu-Serve or something like that. You can almost get the E Machine for free. Buying a used computer might be another option. I hope he at least has a monitor. Good Luck.
Ethernet
204
For $400 bucks I'm getting a t-bird 800 with motherboard, 256 meg of ram, and a geforce DDR - just use price watch, stuff is cheap lately.
CigarSmokedByClinton
408
BigLance:
From what I can tell, and according to FIC's webpage, that motherboard does not have onboard video. If you can show me otherwise, that'd be great as I am looking for a board to put a duron in that has integrated video. Thanks
Cigar
BigLance
1,206
sitka, thank you very much !!
CigarsmokedbyClinton, you are probably correct here, I ran some queries on pricewatch to come with the information for him, on the description it said there was onboard video, however, there is a good chance that was an error...
There are other boards I imagine that have onboard vga and support Duron however I am not a Duron person and do not know :(
But you could pickup say a 8MB TNT2 card for about $28. Or spend a little more and get like a V3 or something...
Madcowz
2,652
okay he may have a $400 cap now... any other suggestions? Compgeeks has some pretty WEAK barebones available now, another other places?
chiwawa626
12,013
400?, might as well go for a system with the msn 400 dollar rebate! buy a $150 sys, the 250 for msn 2 years....good comp
