- Jul 29, 2006
- 109
- 0
- 0
I've got a 5 year old Samsung SyncMaster 955DF 19" CRT, it's worked without a problem the whole time I've had it. For about a day I had a small crt television that I put on the table next to it, and I didn't notice anything bad until after quite awhile, when I saw a little distortion. I moved the TV away and everything was fine.
Now a couple days later the whole screen is flickering and has moire (?) patterns on both side edges. Kind of like water ripples but vibrating. I tried the monitor's degauss feature repeatedly. For a little while yesterday it was back to normal but all of today its been *horrible*.
Is there anything I can do? Any chance it will go back to normal? I guess it was probably caused by the TV being near it, or just old age, although tomorrow I'll try repositioning it in another part of the room and see if that helps.
(Alternative question if anyone has thoughts. . what would you recommend as a good 19 or 20" LCD for gaming, under $400?)
Many thanks in advance for any suggestions!
