Help!-My computer keeps freezing up
LynneN
7
I need some help diagnosing a problem with my computer. It freezes or locks up on me when it has been on for a couple of hours. I have the AMI Desktop Client Manager installed. It says my CPU fan status is 0 rpm and that there is a voltage warning on my board. Neither of these things is factual. I have 3 fans inside the box and they are all running. I had the voltage checked, and it is right on the money.
The person who checked it thinks it might be my motherboard or possibly my CPU, but he said that there was no way to check it out. That I would just have to replace them both in hopes of fixing the problem. I don't like that solution, and I can't afford it.
I don't know exactly which of this info will help but here goes. I have a PC100 - M598 main board, 333 mz, AMD K6(R)-2 processor, AMI BIOS, 6.4 gig but only using 2.3 of them. Is this enough info?
Does anyone have any suggestions? I will appreciate any help you can give me. Thanks. Lynne
KGB
3,042
What OS are you running?
By your system specs I assume you have had this system for a while and it had been running OK. Is this correct?
If this is correct, have you added any software or hardware or changed drivers lately; deleted or incorrectly uninstalled any programs?
Please elaborate.
jeremy806
647
Sounds to me like the motherboard or BIOS has some issues with power management support.
Assuming that you are not running w2k, disable all apm stuff in windows and in the BIOS and see what happens.
jeremy
