**************Help My Computer does Not Work**************
Speed45
I Had My Computer And I Took It To Georgia For 2 Weeks And It Worked And Then I Brouht It Home After I Pluged It In And It Loads The Computer But I don't See Anything On The Moniter And The Moniter Does Not Turn On Why?no the moniter is onbut it shows nothing when the computer is onIt is pluged in all the way
CombatChuk
2,008
While you were traveling, it might've been possible that the Video Card came loose from the slot. That's what I think it might be.
Nick Stone
1,033
Something probably shook loose. Reinsert and re-attach everything until you find it.
CPU, Ram, video card 1st. TAKE THE VIDEO CARD OUT and put it back in again. Then check cable connections.
Double check the obvious connections like video and power.
If your computer was in your car, I hope you put it in the seat so that it wouldn't get shaken around too much.
Got any beeps when starting up? fans running? keyboard lights? panel lights on front of case?
