I checked the cpu core, it's fine no crack or anything, plus I use cpu shim, so it minimizes the chance of cracking my cpu core. When I boot it, it stops at videocard check. I tried reseating the RAM, didn't work. I tried booting if for 5 secs w/o the HSF, didn't work. Also, When I plugged it the power chord and switched the switch in the back on the power supply, my computer turned on right away, I mean, I could not turn it off by pressing the power button in the front, I had to use the switch in the back. I checked the cable and it was fine. Please help.
Thank you
Thank you
