Well, part of it is actually my case...the cut out area is smaller than the back plate.......There back plate meets ATX 2.03 and ATX 2.01 specifications...there board doesn't. its a 1 mm to high..
Therefore, its not compliant with ATX 2.03 specs.....oh well...time to deal with them...
......hmmm....i will try and ask them to replace it with a version without audio but with all the rest..,,don't really want that audio out any way... with the fire wire...6 USB.......
Does any one know who to mail as i want to keep it quick.. i am sure i am goin to get that usual script you get from Tech support.
Any way....any one know what type of file I should get to file away some 1mm thick steel plate ?
