HELP!!!!, MSI pro2A sound card help
mhan80
85
I am on a budget so I am using the onboard sound card. In the bios do I enable the SOund blaster? and what about MU??
Moonbeam
74,619
6,717
I'll face this tomorrow. Did you read the manual? Just bought the Pro 2A and no sound card.
mhan80
85
yes i read the manual and it works just want to know if it will sound better if I enable sound blaster. Or does this mean i need to buy sound blaster then enable?>
DaddyG
Banned
Mar 24, 2000
2,335
Sound Blaster usually refers to SB16 emulation, which is not required.
On El Cheapo sound cards, I have found that the software wavetable simulation provided by Microsoft works better than MU. Just try both.
