Help!! Motherboard Monitor 5 and 8K7A+
skrill
1,079
I am trying to use MBM5 to a monitor my temps. I downloaded the program and its seems to work fine -- except it doesn't show the temps (everything just reads 0 degrees).
Did I set up the MBM5 incorrectly?
MichaelD
31,528
MBM5 isn't easy to set up; that's why I stick w/Via's monitoring utility. Anyway, in MBM you need to set it up so it knows "which sensors" to read from. There's a list of about 20 to choose from, and they have some kind of archaic numbering sequence that I don't understand....that's why I don't use it. I know others will be able to help you though!
