help motherboard install on enlight 7237...
stanger
188
I have an enlight 7237 ATX case and gonna install the ASUS CUSL2-C motherboard on it.... ok the case already has 6 small metal stands that the motherboard i guess sits on and there are a few more in the bag of bolts from enlight. I dont see any washers of any type does the motherboard sit right on top of the metal stands without any insulators between the board and MB tray? i was worried because i have read here about some type of red washers that comes with the cases, i just dont want to fry a new motherboard so i wanted to check with you tech guys first :)
stanger
jstdenis
11
Just installed Iwill K266 in that case. No washers needed here; just added a few standups(included in the bag of bolts)to mate with mounting holes on MB. I think the worst that can happen is short to MB and no boot; no nothing. If you experince prob boot up outside case. If it boots outside the case but not mounted in the case then you have a short to MB prob.
GAZZA
1,987
Just make sure that the holes line up correctly to the screw posts and you'll be fine , those holes are isolated so you wont have any issues but if it makes you feel any better you can always use some thin card or even plastic in .between
max105
1,139
i've got almost the exact setup as you except I have an CUSL2 motherboard. I think theres only a total of 6 screw mounts for the motherboard and the case to connect. I don't have any washers between the case and the motherboard and it's runninng fine. Never had any problems, so i don't think u should either.
