the black is not part of the screen - it's the black just as if the monitor was off...
It happens every now and then, used to happen a lot with win98, once in a blue moon with XP (not for a long time)
Right now I am in Ubuntu (Linux)
and then I was configuring XF86Config-4 and it happened again... is it related to refresh rate?
Basically, the entire screen gets smushed with the screen usually 2" in from each side and extending the upper and bottom parts 1"+ outside the edge of the monitor... the right side of the visible image on the screen usually has a brighter-than-the-rest vertical line in the image extending from top to bottom of the visible image. for example, if this was in Windows, the start menu would not be visible at all cuz it would be below the monitor and any icons in the top corner would be gone too, off the top of the monitor
this was supposed to be 1152x864.... I have this oddball resolution b/c 1024x768 nearly ALWAYS did this to me in windows.... so I've just used this and stuck with it
Any info is appreciated!
THx
THx
