Help! Mom got her neck dyed!
bootymac
9,597
Ok, so my mom went to dye her hair at the salon today. The guy forgot to put some tape on the back of her neck to prevent the dye from getting on it, but being the dumbass he is, he forgot. So now the back of my mom's neck is partially darkened.
So the question is, what could she use to remove it quicker?
Thanks
tm37
12,436
Originally posted by: bootymac
Ok, so my mom went to dye her hair at the salon today. The guy forgot to put some tape on her neck to prevent the dye from getting on it, but being the dumbass he is, he forgot. So now my mom's neck is partially darkened.
Thanks
Lighter fluid.
or fingernail polish remover.
Dec 28, 2001
11,391
Thanks
Lighter fluid.
Then burn it off?
bootymac
9,597
Thanks
Lighter fluid.
Then burn it off?
My thoughts exactly :D
LethalWolfe
3,679
You can also buy stuff that is specailly made to remove hair dye from skin. I don't know what it's called, but any place that does dye jobs should have some (or at least be able to tell you where to get it).
Lethal
bootymac
9,597
Ok, thanks for all the help guys. I'll tell my mom the things you guys suggested, and let her figure out what to use.
Thankssssssssssssssssssssssssssss
