Help! Mobo is making a Beeping noise!
ShadoWing
Like I said before, the mobo just has this huge long beeep that it sounds off when the computer is off. However, once i turn it on, it's all ok and everything works fine.
I know it's got something to do with the graphics card i just put in, from a 6600 gt to a 6800 nu. However, I'm not sure what's happening, since the 6800 makes the mobo sound off but works fine. Help please!
im usin an antec truepower 3.0 350 watt, i've tried reinstalling it but to no avail. It only beeps when turned off
Call the company that made your motherboard and call their technical support line and describe the beeping noise to them. Or you can try reading your motherboards manual and see if they have a list of the different beeping noises and what they mean. Because specific beeps or how many times it beeps, is because of a certain issue. Hope that helps mate.
I forgot to mention, I don't really think it's your power supply, because then you would just have random reboots and your system would just be very unstable. So, I really don't think your power supply is causing the beeping noise mate.
