HELP: Misc Problems w/ Soyo Dragon System
kainoa
Hello Everyone,
I just put this system together about 2 weeks ago and could use some help/input on some problems i've been having:
Soyo Dragon MB, bios ver. kvxa2ba2
Athlon XP 1800+
Thermalright SK-6, Arctic Silver II, Sunon 60mm 4500rpm fan
512MB Kingston DDR
IBM 60GXP 60GB
Plextor 12x10x32x, Zip
GeForce2MX
Pinnacle DV200
Antec 830 case, 300watt PS
4 Enermax 80mm Variable Speen Case Fans
1. When I shut down the comp from windows or the power button, the system and fans shut off. But when i open the case i see the led on the mobo still on and i still have power on my keyboard and optical mouse. The only way i can totally cut the power is by flipping the switch in the back of the PS. This sux cause i dont want to have to reach in the back of my comp everytime i want to power down. I checked the bios and all the power management settings seem in place. I can't tell whether or not this is a PS or mobo problem. Please advise.
2. Aside from the problem above the system ran smoothly throughout the first week (CounterStrike, Photoshop, 3DMax, no prob). Now, all of a sudden i get freezes and lockups at various stages - @ post, @ winXP loading screen, @ 5-10 mins after winXP loads, even after booting into a dos prompt! Sometimes when i reset, it gives me a black screen. Ive flashed to the latest bios, cleared my cmos jumpers, and tried switching my ram into diff slots. Still unstable.
Thanks in advance for your help!
:D
DoubleL
1,202
Well the power lights are normal and the lockups could be from a lot of things, Is your processor running cool, Maybe you are not getting enough power with the 300 watt power supply, Could be weak memory or a bad chip on the memory I have had that problem and it does the things you are talking about, Have had a harddrive give me problems like that to, Could be a driver problem, I know I wasn't to much help but it is one of them hunt till you find it things
