- Apr 30, 2005
- 119
- 0
- 0
Nutshell: Turn the computer on, looks like it is posting, (optical drives flash), HD spins, but no signal to monitor. If I leave it, it will just sit with the fans going and won't go into XP. If I shut off the powersupply, and pull out all the USB devices it will boot normally. Then I have to plug all the USB devices back in.. I have the latest firmware on the mobo, and all the latest drivers...It just started doing this after it sat for a month turned off while I was out of the country. Any suggestions to a fix? Or has anyone else had this problem?
Build:
MSI K8N Neo4 socket 939 mobo
2 512 Corsair VS
MSI x800XL PCI-e
AMD Athlon 64 1.81GHz
WD 250 gig
Antec power supply
Nothing is overclocked.. and the system keeps cool, the CPU doesn't go over 120F.
Thanks
1fast.
Build:
2 512 Corsair VS
MSI x800XL PCI-e
WD 250 gig
Antec power supply
Thanks
1fast.
