OK...my setup is this:
AquaXtreme 50Z-DC12-T Mag Drive Inline Pump with 1/2 OD tubing to a Swiftech Apogee Extreme Performance Universal CPU Water Block which goes out to a Danger Den VPU water block then to a Thermaltake CL-W0002 12cm Big Radiator and up to Thermaltake CL-W0031 AquaBay M3 Liquid Tank reservoir and then back to the pump. All tubing is the same size 1/2OD 3/8ID. I recently put this new pump on and its a much heavier duty pump than my old Thermaltake pump and right away after priming it I noticed million of tiny air bubbles. It seems that there are so many that they don't have time to bleed out when running...it almost seems like the water is being pushed through so fast it doesn't have time to bleed out into the reservoir. If I turn off the system overnight the bubbles are gone but come right back once the system is up and running for a short time. It seems they come from the Reservoir...now, there are no leaks. Can it be that because the Reservoir has 1/4ID/3/8OD tubing coming in and out of it and I've got 1/2OD couplers on them to accomodate my tubing that the reservoir can't keep up with the pump? Help, whats the use of a water cool system if its full of tiny bubbles...last thing, I don't understand bleed lines and how they work...maybe thats what I need...suggestions???
