HELP!!! Memory Stumper.
TheCandyman
155
I just received 4 chips (168pin DIMMs) but they won't fit in any of my mobo's
I lined up the pins with the slot and found that the first alignment pin was off by about 1-2mm
Since it can't fit (It won't even be forced in) I don't even know if it works.
Any suggestions?
TunaBoo
3,280
The offset hole means it is ECC or registered I think. Hang on let me bust out the book.
TunaBoo
3,280
Ok there are 2 nothces in SDRAM. One in the middle, and one towards the end.
The middle one either means:
1) 5.0V
2) 3.3V
3) Reserved aka Mystery
The one towards the end means:
1) Reserved aka Mystery
2) Buffered
3) Unbuffered
Thank Scott Mueller's Upgrading and Repairing PC's 12th Edition
Oyeve
22,048
877
Its 5.0v EDO memory. Very common on the Pentium Pro PC of yester year.
