Recently built a new system with an Asus P5K-E motherboard and C2D 6750 cpu at stock speeds.
Unfortunately the motherboard refuses to report the correct temperature - I'm getting BIOS reports of 17-18 degrees. Tried several different firmware versions but no help.
The HSF on this chip is a Thermaltake Ultra 120 with the supplied thermal grease used, and attached 1200rpm Scythe 120mm fan.
Even still, I don't believe the temp would be that low with air cooling. I tried Speedfan and Coretemp but they didn't help much either (values still too low to be realistic).
I'm going to take it all apart in a few days and clean everything, then use some AS5 paste instead and put it all back together. Can someone with a roughly similar setup tell me what idle/load temperatures I should be seeing? I want to do some overclocking and need to know what sort of temperature offset to use in Speedfan.
Help appreciated!
Help appreciated!
