Help me work on my website!
xaigi
I have a website that provides free, temporary, anonymous email recieving addresses. Spamhole.com. The system is setup to require no logins.
Everything works fine; the only problem is that I dont think the site is aesthetically pleasing enough. I also wonder if there is any other information that I should put on it.
Any ideas? I'm only getting a few thousand hits/month.
BurnItDwn
26,355
1,867
Cool idea for a site ...
more asthetically pleasing
well .. perhaps set up some tables or something .. it looks like its just all splattered on there with no order
like .. put all the links on the or on teh top maybe ... and then put the adds spread throughout the content in the middle
maybe double space the text
and possibly do something with the background ... a plain white background is boring ... throw in a simple repeating background (not an annoying one though) or use tables, and color the cells in some pattern that looks appealing ...
theres lots of things you could do to make it look nice and still serve the same purpose
hope these ideas can be of some help to you
Taz4158
Banned
Oct 16, 2000
4,501
It's a good idea. As for eye candy, I don't think you need it. It gets the point across what you do and maybe that's all you need?
ArkAoss
Banned
Aug 31, 2000
5,437
yes very neat idea, spamhole, tables oughta clean it up enough. but it gets the job done, trust me.
maleficent
468
Great idea!
The contrast of the text/background/graphics is too extreme. Maybe the background could be a slightly less white. Also, you might try breaking up those paragraphs. People tend to skip over paragraphs. They read the first sentence and often skip the rest. They're more likely to read it all if it is divided into units of 1 or 2 sentences. Vary the look of the text.
