nboy22
I got this board yesterday and have been TRYING to get it to boot up with my athlon 64 3000+. The problem is, after DMI verifying, it says I need to insert a system disk even though windows xp is already installed on my existing hard drive that IS on master and IS on my primary cable. The weird thing is, I thought I might as well just boot up and install windows xp pro again, so that's what I did, Worked fine!........ until I restarted, and it did the EXACT same thing as before, "Please insert a system disk"... PLEASE help, this is getting me mad, I've turned off raid, and I'm just running regular IDE drives, here's how it's setup. Primary cable: 120 gig WD on master, and 80 gig WD on slave. Secondary Cable: Cd burner on master, Seagate 80 gig on slave.
I know my computer detects these drives because it shows them all in the correct order in the post, but why is it not seeing the OS on the 120 gig HDD if it can read off of the drive?
