Help me with this minor problem.
aolj
I'm multibooting WinME and Win2k.
My Win2k went cranky so, I just formatted the partition from within WinME. From then, I would still have the booting option of win2k and winme.
So, I installed win2k again from scratch. Right now, at the boot screen, I have 3 options to choose from.
WIN2k
WIN2k(This one doesn't work)
WINME
How do I get rid of the one option that doesn't load win2k. In win2k, it only let's you select which one to be default and the time to load.
Help pls. Thanks.
There might be another way but I know this works because I have done it. Go to C:/Boot.ini. It might or might not be hidden and it is read only, so you'll have to undo that in folder options. You will see a list of OS's and the default one, the one that automatically boots up. Just delete the line with the one that doesn't work. Be sure it's the right one though. Good luck!
