- Jul 28, 2011
- 60
- 0
- 66
hello all, i am going to buy an ssd in the coming days and need your recommendation on which one to get. I decided for a 120 gb unit, it will be for my notebook, a first gen core i5, i think it is only sata2. I need it to be very reliable (since i live in paraguay, southamerica and wont be able to return it in case of failure), i was thinking on a intel 320 but there is the 8mb problem (which im confident will be solved since intel already reckon it ) what about the intel 510? is there any know problem? I know its a sata3 device but if it is not much pricier it doesnt matter. Or any other you could suggest me? i will be buying from amazon.
THANKS
THANKS
