Help me with PHP please.
ibex333
4,094
123
I have 3 files. 1 HTML file, 1 PHP file and one CSS file.
When I run my index.php my "echo" statements place their output on the upper right of the webpage, but I want them right next to my labels. I want scores output to be placed next to scores, Score Total next to Score Total and so on...
I tried googling for this, but no matter how much I search, the darned thing still tells me my variable is undefined! I am completely lost. I have no idea what I am doing wrong.
Don't worry about the unfinished code for dice rolls. I will deal with that later once I understand how to properly output my results.
index.php
Code:
<!DOCTYPE html>
<html>
<head>
    <title>Loop Tester</title>
    <link rel="stylesheet" type="text/css" href="main.css"/>
</head>
<body>
<?php
$action = filter_input(INPUT_POST, 'action');
if($action == 'process_scores'){
//ECHO "SCORES";
$scores = $_POST['scores'];
//var_dump($scores);
$score_string='';
$score_total=0;
$score_average=0;
foreach($scores as $score){
$score_string.=$score.' ';
$score_total+=$score;
echo $score_string . '<br>';
echo $score_total . '<br>';
$score_average = $score_total/3;
echo $score_average . '<br>';
else if ($action == 'process_rolls'){
    ECHO "ROLLS";
/*$rolls = 'number_to_roll';
$sides = 6;
$results = array();
for($i = 0; $i < $rolls; $i++) {
	$results[] = rand(1,$sides);
echo "Each roll:<ul><li>";
echo implode("</li><li>", $results);
echo "</li></ul>";
$total = array_sum($results);
echo "Max: $total<br>";
echo "Average: ". $total / count($results);*/
include 'loop_tester.php';
    </body>
</html>
loop_tester.php
Code:
<!DOCTYPE html>
<html>
<head>
</head>
<body>
<main>
    <h1>Loop Tester</h1>
    <h2>Process Scores</h2>
    <form action="." method="POST">
        <input type="hidden" name="action" value="process_scores">
        <label>Score 1:</label>
        <input type="text" name="scores[]" ><br>
        <label>Score 2:</label>
        <label>Score 3:</label>
        <label>&nbsp;</label>
        <input type="submit" value="Process Scores"><br>
        <label>Scores:</label>
        <span>"<?php echo $score_string; ?>" ></span><br> [b]<!-- WHY THE HECK IS THIS UNDEFINED, AND HOW CAN I GET IT TO SHOW PROPERLY? -->[/b]
        <label>Score Total:</label>
        <span></span><br>
        <label>Average Score:</label>
        <span><span><br>
    </form>
    <h2>Process 1000 Die Rolls</h2>
    <form action="." method="post">
        <input type="hidden" name="action" value="process_rolls">
        <label>Number to Roll:</label>
        <select name="number_to_roll">   <!--   If possible, change this to do the same with a php loop-->
            <option value="1">1</option>
            <option value="2">2</option>
            <option value="3">3</option>
            <option value="4">4</option>
            <option value="5">5</option>
            <option value="6">6</option>
        </select><br>
        <input type="submit" value="Process Rolls"><br>
        <label>Maximum Rolls:</label>
        <span></span><br>
        <label>Average Rolls:</label>
        <span></span><br>
    </form>
</main>
</body>
</html>
main.css
Code:
body {
    font-family: Arial, Helvetica, sans-serif;
main {
    width: 450px;
    margin: 0 auto;
    padding: 1em;
    background: white;
    border: 2px solid navy;
h1 {
    margin-top: 0;
    color: navy;
label {
    display: block;
    width: 8em;
    text-align: right;
    margin: 0 0 .5em;
    padding: 0 1em;
    float: left;
input, select {
    display: block;
    float: left;
    margin-bottom: .5em;
    margin-top: 0;
br {
    clear: left;
purbeast0
53,767
6,646
you said you have 1 html, 1 php, and 1 css file, however you posted 2 php files and 1 css file.
Ken g6
Moderator
Dec 11, 1999
16,839
4,820
75
I see. You're including the loop_tester.php file from index.php, and the variable you're looking for doesn't get passed through. It's probably a scope thing. You could try declaring the variable global in loop_tester, but that's an extra line. Or you could use the $GLOBALS array.
P.S. Seems like a better style would be if the inclusion went the other way, but maybe that's just me. And it would take a lot of reworking.
purbeast0
53,767
6,646
loop tester is a php file that only has html code in it so far.
there is PHP code in looptester where you are having the problem.
i was just unsure if you were missing something in the info you included, which is why i asked.
i'm also pretty sure you are going to have two <head>, <html>,<doctype> and <body> tags based on the way you have it written right now. it's been a long time since i've done php, but I thought the include command literally just copied the contents of the file you are including into the spot you are including it.
ibex333
4,094
123
Yes, that's exactly it. Are there any other ways to pass in my variables without reworking my files too much?
