So my antec case comes with two standard case fans and I am debating how to set them up. 2 openings on upper back, 2 at lower front and one at the side.
the 2 in the front and the one on the side should be blowing in, the 2 in the rear should be blowing out, mod them to 7V or 5V to reduce the noise, and/or use good fans with ball bearings.
btw I got a 4 degree drop on my case temp having one intake fan on the side and one outtake on the back. Previously I had them both on the back out taking air it's all good
typically you want to even out your intake fans to your output fans, since your psu pulls air out as well if you had 2 fans you'd want 1 in and 1 out, if you had 3 fans you'd want 2 in and 1 out....etc. etc.
