help me with my comp settings..
opexes0
hiya i got asus a7v333 motherboard with amd 2100 mhz
but i dont know how to set it so i'll run at 2100
i also have 512mb of pc3200 400mhz
and pny geforce 6800 128mb
what setting should i put for these?
freqency multiple
pci freqency
memory freqency ratio
vcore setting
vcore
please help me..
Fern
26,907
174
the 2100+ actually runs at 1733mhz. So if that's the speed it's at, you're OK
freqency multiple
pci freqencyKeep at 33mhz
memory freqency ratioYou want to run insynch on this system for best performance, so 1:1
vcore setting
vcore
please help me..
Fern
26,907
174
Looks like there are two versions of the 2100+. Both look be 133 FSB and use a multiple of 13 (frequency multiplier). Vcoe of 1.60volts
opexes0
thx im running it.
multiple of 13
133/33
vcore on auto at 1.750
it's currently running at 1.73mhz
however it burning up.. really hot
sucks cuz everytime i reboot it gets too hot it doesn't boot up
i ran fine at 1.3mhz but that's not running at top speed
a dilema shouldn't it suppose to run fine at 1.7mhz with stock fan and sink? i guess i gotta invest in alternative cooling method.
mechBgon
Oct 31, 1999
30,699
Check the heatsink's installation against the photos and concepts on this page. One thing to be aware of: the phase-change patch on the original heatsink melts to fit, ONE TIME ONLY. After that first melt, if you remove the heatsink, replace the melted patch with high-quality thermal grease.
