Hi.
In mid jan, i`m doing a PC upgrade. With an Asetek waterchill kit. After alot of measurement, ive concluded that theres no a cat in hells chance that the Rad will fit in my case without extensive modification, which im not willing to do.
So, after re-budgeting the next couple of months a little, ive managed to get £100 to spend on a new case.
Needed Spec for case;
--Has intake and exhaust (not just one or the other).
--Either the intake or exhaust must be a 120mm(for easy mounting of Asetek rad/fan)
--As at least 3 5.2" external drive bays, 1x 3.2" external, 2x 3.2" internal (preferably more internal 3.2" drive spaces)
--Costs a maximum of £100. No more.
--Must be from OverClockers UK.
I would also like, but not essential;
--A case window, or the ability to buy one for it seperately.
--"Quiet propeties", sorta like what the sonatas have.
Now, ive had a look around the OCUK website, and for the 120mm fan mount requirements, it seems that im limited to Antec cases, which is no bad thing.
I conclude that;
Antec P160 Anodized Aluminum Super Midi Tower case
Will fit my needs quite well. And its just about in my budget (£99.99)
The Chenbro Gaming Bomb seems to be good as well, and is well within budget.
I could do with opinions on the above, and suiggestions on the other cases that OCUK do.
Thanks in advance guys/gals.
And have a happy new year!
I conclude that;
