- Jan 6, 2002
- 22,976
- 1,178
- 126
Tiny ass EVGA Hadron, right now it has the 2 stock 120's on top blowing out, and I have my Cooler Master TX3 mounted horizontally with the fan facing up. There's not enough room on the bottom side between the heat sink my video card to mount it there.
I'm going to be ordering 2 120mm fans, I'm also looking at some 92mm/14mm Noctua fans for my heat sink and 2 of their 120mm flx for the top. I'm taking a guess that with them being thinner than the stock 92mm fan on the heatsink I could mount 1 on each side. Here's my questions:
Would it be better to mount the heatsink vertical and have the fans facing the front and the back of the case? I'm not even sure if it'll fit that way, but if it will would it be better? Also, should I switch the top fans to intake? The PSU has some funky tiny 40mm fan on the bottom blowing out of the case's bottom mesh. I don't think it can posibly be doing much though.
