Help me with a simple physics question
Lizabath
125
A baseball player throws a ball from left field toward home plate. Assume no air resistance, at the instant the ball reaches the highest point, what is the direction of the ball's acceleration? Why?
possible answers:
a. Up
b. Down
c. Horizontal
AgentEL
1,327
Assuming no air resistance, what forces are acting on the ball? If you know the force(s), you will know the direction.
jyates
3,847
I'll take a stab and say "down" ......
Assuming that you have gravity that is.... :)
dullard
26,201
4,871
There is only one force, and thus the acceleration is the same no matter what point the ball is at. The answer doesn't change whether it is at its highest point or not.
notfred
38,241
4
B. It's always B, regardless of the point in it's flight path (unless it's still in the pitcher's hand).
Lizabath
125
exactly.
I got it now.
Only one vector of force is acting on the ball, not two.
Thus the answer have to be Down. Acceleration -9.8 m/s^2 from gravity.
ActuaryTm
6,858
12
Assuming no air resistance, what forces are acting on the ball? If you know the force(s), you will know the direction of the acceleration.
With the inclusion of the portion added above, follow this advice.
JonnyStarks
1,682
break it down into horizontal motion and vertical motion
at the top of its flight, its not moving up or down.
however, it is still moving horizontally. I guess technically you've already applied the force, but its velocity would be only horizontal.
or something like that... im tired right now
JonnyStarks
1,682
exactly.
I got it now.
Yeah, that sounds better
JDub02
6,209
yep. the force of gravity is constant from the time it leaves the guy's hand. assuming no air resistance, there are no other forces acting on the ball.
Peetoeng
1,866
possible answers:
a. Up
b. Down
c. Horizontal
c. but the 'no air resistance' makes the problem unrealistic. Ball leaves the pitcher's hand with an initial acceleration (in x, y, z direction). The z-component of acceleration decreases due to gravity; at the highest point, the ball's z-acceleration is zero. But since 'no air resistance' is assumed, the ball would maintain its initial x- and y- acceleration which is obscure. Nothing stops the ball until it hits the ground or a fan's head.
Anubis
78,712
427
tbqhwy.com
3rd ed
maziwanka
10,415
possible answers:
a. Up
b. Down
c. Horizontal
boo yah!
MacBaine
Banned
Aug 23, 2001
9,999
possible answers:
a. Up
b. Down
c. Horizontal
Lot's of physics failures in the thread today.
Clarification: I'm talking about you. Oh, and maziwanka now it seems.
Nov 7, 2000
16,403
from the instant the ball leaves the hand, there is NO FORCE OTHER THAN GRAVITY acting on the ball. The horizontal speed (nor direction) is not changing (ie no acceleration) (there is no force in that dimension). The answer is B, and it is for the entire duration of the flight (not just the apex). The answer has been posted already I know, but there are also some wrong answers so I thought I would reiterate.
edit to clarify a little more -
the downward acceleration causes the balls vertical velocity to slow down on its way up, and increase on the way down. in both instances the direction of the acceleration is downward. also the ball is assumed to be travelling at a constant velocity after being launched from the hand.
Heisenberg
10,621
possible answers:
a. Up
b. Down
c. Horizontal
Beat me to it.
maziwanka
10,415
possible answers:
a. Up
b. Down
c. Horizontal
i was wrong. its clearly b.
Titan
1,819
Tanswer is definitely not C. I'm glad to see i'm not the only one who got an A in physics in the thread.
Based on canonical assumptions, the answer is B (down). But the question gives a poor image in describing the reference frame. In the proper frame of reference, any of the answers could be true. The question really needs to establish a clear frame of direction before it can be answered fully.
