NeezyDeezy
Hi, I am going to build my first computer this holiday while I am off work and can fiddle with learning and building up a new comp almost from scratch. I will be doing no gaming on this comp. Instead, I'll be doing a lot of multi-tasking, with multiple torrents open with bit-torrent, music, watching HD video, and browsing. My plan is to wait for the new line of dell monitors to pick up the 2407 and use this rig sortof like an HTPC. I may not need high-end components for these purposes, but my budget is no more than $1100 (w/o monitor... prefer 1000 but if there's something that would really help that bumps it over, I'll consider). If I need better equipment later I'd like to be able to upgrade when I buy the tv card, etc.
I am starting with the following from my old system, a 16x NEC burner, a 200GB PATA HD, and logitech z-2300 speakers.
So I figure I would go with the best CPU and MOBO for the money, which I've been told might be based on something like this from monarch:
Pre-Tested and Setup AMD Athlon 64/FX/X2/Opteron 100(939) Combo
Motherboard: 110799 - DFI Lan Party UT nF4-D Audio/GB-LAN/IEEE/ $115.00
Processor: 120338 - AMD Opteron 165 Dual-Core 1.8GHz 1MB $339.63
(the 170 is only $30 more... what to do?)
eatsink Fan: 130956 - Thermaltake A1770 AMD Opteron/64 Heatsink $11.95
Memory: None
2nd Memory: None
Round Cables: 270153 - Round Cables UV Kit 2-24" IDE 1-18" FDD 1 $22.00
Warranty: 800056 - Motherboard-CPU Warranty - 90 Days $5.88
and then for RAM, maybe this:
1 GB (2 pcs 512) DDR (500) PC-4000 PQI Mirrored Black (PQI4000-1024DB) $116.00
PSU: Antec TP2-550EPS ATX 2.01/EPS/SSI 550W Power Supply $86.99
Total = $743.09
The only other thing I need would be a good boot drive, but I defer to your suggestions on that one because I don't know what would be best. And as for a case and videocard, that shouldn't be too much more $, whatever is necessary for tv watching/capturing.
I'd really appreciate any input... I won't OC the CPU until I'm sure I know enough about it to safely make a conservative adjustment. In the meantime, I just want to assemble my first system. When I do, I guess I will need a better fan. Any suggestions? Sorry for the lengthy post.
If you want to throw out the component ideas here and start from scratch, please do so, just explain why.
Thanks a ton!
Memory: None
2nd Memory: None
Total = $743.09
Thanks a ton!
