So far I have purchased a 17" lcd (princeton senergy $190 AR) and 512 mb of pc2700 ddr memory ($30 staples deal), and an antec mid tower case w/350 watt power supply ($40 AR from best buy).
I will be using this system for web surfing, office apps, occasional photoshop usage and an occasional game or two. I am leaning towards the 6600gt video card in order to play some newer games, but this might be overkill for me. I will be purchasing an 80 gig hd, and will use my current dvd burner in this system.
I have been out of the loop for a couple few years as far as motherboards and cpu's go. As you can tell I am a bit of a cheapskate and usually like to stay a little behind the newest technology. I told myself I was going to try AMD for my next computer, and am not opposed to the sempron. What do you guys think would be a good choice for a motherboard and cpu combo? I saw fry's has the ecs board combo with kt600 chipset for around $75. I cant remember what processor that comes with. Is this worth getting? Any other budget but good quality stuff out there I should look into? Also is the 6600gt overkill for me? Thanks a lot if anyone is willing to help out an old geek who had a commodore 64 as his first computer.
