- Dec 12, 2012
- 5
- 0
- 0
Been thinking of building a budget pc. It will be for entertainment and games like BF3, BlackOps2, Fifa 13, Assassin's Creed 3 etc. So anyways I don't have a large budget so I need to keep it all under $300 (excluding the monitor). Tell me if I can get decent framerates on high settings at 1080P
1. Intel Celeron G860 Dual core @ 2.8 Ghz
2. 1 X Adata 4G @ 1333 Mhz
3. MSI H61M-S26
4. Western Digital Caviar Blue 500G 7200 RPM SATA 3
5. Antec V450P 450 Watts
6. Galaxy GeForce GTX 560 Ti
As you can see it is quite low spec and I've had to make a lot of sacrifices with the CPU and mobo to be able to afford a decent GPU (if you can call that decent
) so my question is what do you think of this build and will it play those games? This is also going to be my first pc build and big upgrade from my trusty semi-gaming acer laptop with Core 2 duo @ 2 ghz with 9600M GS 512 Mb.
Thanks guys
3. MSI H61M-S26
Thanks guys
