Bloodstein
Hi guyz,
I've got a dilemma. After months of searching....I have found my laptop of choice - IBM T40 (feel free to reconfirm my choice 😉 ). However, choosing a T40 seems to be a prob for me. The T40P is totally outta the qs...way too expensive for my budget. 1.30GHz is also kidda out. I'm looking at the 1.5GHz range. In particular, models:
237375M
237372M
The only diff between them is that 72M has the Intel Wireless Card. 75M has the Cisco 802.11b card. Also the battery life (according to the IBM specs) seem to post the 75M as having 4.5 hours compared to 5 hours with 72M. Now, which one do i go with? They're both the same price.
Also, do advice me on second battery. Does the standard 6-cell do the job or would it be wise to buy another 9-cell. Based on ur experiences, what would be the average battery life that I can expect?
I'm a lil' scared of taking the dive now. My situation is such that I won't be able to return the laptop if i dun like it. If you guyz could post ur experiences with the T40 screen resolution, that would help as well. Are there any quirks that i can expect with these particular models? Could owners of these particular models pls post their experiences.
Thanks a lot guyz.
237375M
237372M
Thanks a lot guyz.
