Question Help me upgrade wireless card in my laptop
ibex333
4,094
123
Hello,
I have a Lenovo G50-80 Laptop. It's old, but it serves my needs just fine. Lately its wireless performance stared dropping to the point where its virtually non existent. I get one bar at beast and it constantly disconnects even though I'm right next to the router. I tested wireless with my tablet and my phone and its perfect. 5 bars. The drivers are up to date too. I opened the laptop and re-seated the card, but there's no change.
The card in question is this: https://www.ebay.com/itm/222764162898?epid=4012037211&hash=item33ddc75f52:g:4O4AAOSwEOpaO2OL
I'd like to try and replace it, but since I'm doing that, Id like to get something better? With faster speeds?
Can someone please recommend a model?
aigomorla
21,067
3,574
What you want is the intel AX210.
This guy:
Here
Make sure you get the BT antenna and Wifi attenna in the proper button connection.
ibex333
4,094
123
This guy:
Here
I like it, its just that its overkill for my Router. My router is AC wireless max. It doesn't support Wi-Fi 6. I could upgrade the router too, but then I'll be in several hundred bucks into this whole thing, when I was planning to spend around $30 max.
What would be a good, stable AC card?
VirtualLarry
56,587
10,225
No, you want the most sophisticated client card currently available, if you're going to upgrade. Unless for some reason that you might have a BIOS white-list.
Reactions: mxnerd
mxnerd
6,799
1,103
All Wi-Fi ax chips are downward compatible with ac & n.
You don't have to upgrade your router immediately.
Intel WiFi chip is the best. If you can't afford $34, how about $14?
Wi-Fi 6 only. Not Wi-Fi 6E.
Well, your Lenovo has whitelist, see if it can be fixed.
Reactions: aigomorla
