I'm planning on upgrading my PC. I'm looking for a new proc, mobo, ram and a SSD.
I've currently got:
Socket 939 Opteron 165
2gb DDR (yes, 4 old school PC-2100 ddr sticks... this alone kills my system)
ATI Radeon 4870 1gb
Audigy 2 ZS
1.5 TB HDD (OS + apps /Media on seperate partitions)
160 GB HDD (Docs / work)
DVD Burner
OCZ 600 W PSU (http://www.newegg.com/Product/...?Item=N82E16817341010)
An old Antec full tower case, w/ 4 80 mm fans
Running Windows VIsta, I was getting BSOD patching to SP1 w/ the 4870. I had a x850 that ran sp1 fine. I figured it was the mobo combination or something. So i've been running w/ pre-sp1 for abt 6 mos now. Longer than i intended to
Anyway: I'm thinking of getting a PII 955, 8 GB DDR3 and one of the 120GB OCZ Vertexes.
What mobo should I get? Can't decide between the 790FX and 790GX; I doubt I would ever go crossfire.
I would like links to specific Mobos and reasonable RAM. I doubt I would OC, never seem to get good results
I am Looking to do the upgrade within the next 2 or 3 weeks but I know that AMD is releasing new processors and the 785 next mo. Should I wait until then for 955/945 "liquidation"? BTW w/ no OC is there a significant difference between the 945 and 955?
I'm looking to game on this rig, tf2, ra3 etc. Hopefully it will handle sc2 at a decent frame rate whenever it comes out. I run my monitors at 1680x1050, so it's not full 1080p rez. I also do some software development and would like to move some of the dev I do into virtual machines.
I don't do photoshop, and don't do media encoding.
So, what say you? Should I be looking at a Core i7 setup instead? I think the SSD would be a killer upgrade.
I've currently got:
ATI Radeon 4870 1gb
Audigy 2 ZS
DVD Burner
