Help me upgrade my PC
mario7770
I played ghosts in ultra settings without a single lag but when i play Battlefield 4 it runs smooth for 10 seconds and a huge fps drop.
pls tell me what is my bottleneck here:
CPU: Intel Pentium G3220 3.0Ghz 4th Den
RAM: Gskill ripjaws 4GB 1600 DDR3
Motherboard: Gigabyte G1.Sniper B5
GPU: AMD radeon HD 7770 GHz Edition 1GB
OS: Windows 7 64 bit
I always play games at ultra at resolution 1600 X 900 since its my monitors maximum that can support.I normally like to play games like BF4,COD ghosts etc.
since im in a low budget , pls tell what should i have to upgrade
every part of your system is a bottleneck for running demanding games on ultra. you need more ram, faster gpu and at least an i5 cpu.
Toyota is right, plus you should make sure you have an adequate PSU.
I would consider another 4 GB RAM, an upgrade to an i5, and a video card upgrade.
Maybe BF is too much for that 7770.
But, before buying anything:
- Update AMD drivers to latest version.
- Reduce image quality and tell us if it improves performance.
Also: Download GPU-Z and monitor GPU clocks when gaming. Check if there's throttling.
