Cerpin Taxt
When I installed Ubuntu 7.04, I used the Alternate Install CD to build a 1TB RAID0 array from 2 500GB HDD. I configured the installation to mount the entire RAID array (md0) as 1 partition at /var.
Then, on the IDE HDD (200GB) I created a 10GB partition for / (i.e. root) and a 2nd partition for the remaining space which is mounted to /home.
I'm using this machine as an HTPC running MythTV.
The issue that is bugging me is that I think the ~190GB partition that I mounted to /home will go largely unused, but at setup I didn't know what would happen if I mounted that partition to /var along with the 1TB RAID array.
How would I reconfigure my system to better utilize the ~190GB partition on my IDE HDD?
I'm thinking I would like to partition off about ~120GB into a new partition and migrate my MP3 collection onto it. Then I could simply re-direct the paths in MythTV to find the collection there. But is there an ideal place to mount the new partition?
Right now my MP3s exist in /var/lib/mythtv/music on the RAID array. Is there a way I could mount the new IDE partition on this exact path and simultaneously remove it from the RAID array? What would be cleanest way to do something like this?
