So I have a Biostar TForce motherboard and a 3600+ AMD dual core AM2 chip with 2GB of Buffalo FireStix DDR2 RAM. I was using a Thermalright socket 939 adapter (so that I could use my old socket 939 HSF). It was working just fine.
I had a XP-90 that I wanted to install on the computer to cool the system better and quieter. Using the mounting bracket adapter, it should work. I removed the old HSF, cleaned the CPU, reapplied thermal paste and mounted the XP-90. However, in installing it I ended up using many tools and lots of pushing and prying. I am used to this since I use custom heatsinks/fans a lot, so it wasn't a big deal until I tried to fire up the system after reconnecting everything. No video! Additionally, there are no LEDs lighting up on the motherboard.
I've tried disconnecting everything and checking the back of the motherboard for signs of short outs or static damage. I grounded myself carefully whenever working on the computer. Furthermore, I tried reseating the RAM, switching the video ports on the graphics card, reseating the graphics card, checking all power connections, etc.
The fans spin up (including the chipset and CPU fan when I reinstalled the old verified good stock heatsink/fan), the power supply seems to be working fine, power is going to the video card, etc.
What is the most likely culprit? It won't POST. The hard drive spins up, but it's not read ever. Like I said no LEDs show on the motherboard (or I'd have been able to isolate the problem). No POST codes displayed either.
Suggestions? I'm about to buy a new motherboard (same model) from Newegg since I don't have the original box >.< and can't RMA it as a result (I think).
What if the CPU got squashed or something when I was installing the XP-90? How can I tell a motherboard malfunction from a CPU malfunction if it doesn't even POST? There is no burning or charring on the CPU. There is no silicon smell either. It's just a mystery...
There are no signs of physical damage on any of the components. I even checked where a tool may have hit the motherboard and I see no marks. Perhaps one of the lanes on the motherboard got squashed? I think the FSB channels are right next to the CPU, so if a tool hit them I am SOL, I guess.
Thanks
Thanks
