My PC of about 3 years was playing AC unity beautifully. Then the game crashed and NVinpsector reset the GPU overclock. Started the game up again played for 5 minutes then the whole system shut down. Now it will not start. If I drain the capacitors by switching the PSU off and pressing the on button until the MB light turns off it will start the fans for about half a second and then shut off.
I ordered a new PSU - same problem. Then I removed the battery - same problem.
Removed GPU - same problem. Then with GPU removed reset CMOS. It starts!
If I put the GPU back in it repeats the fan on for half a second issue. I tried another GPU - same problem.
Could I have blown out the PCI-E slot?
I will pick up a new battery and test when I get home later. Please suggest other tests or possible concerns. If need be I can swing by MicroCenter.
My system:
Asus P8Z77-Deluxe
Intel 3570k O/C to 4.8GHz
New PSU is Corsair AX860
Cooling is Corsair H50
RAM is unknown G.Skill I suppose I can test with it removed.
Thanks for reading.
My system:
Asus P8Z77-Deluxe
Thanks for reading.
