Thanks in advance for looking and helping!
I think my video card is shot! I used to be able to run WOW and Oblivion at High settings, but slowly I was getting more and more artifacts during WoW. I installed the new Catalyst 8.6 Driver and "POW"! It started crashing during the BG's, now it crashes the comp before even getting in. I've reinstalled the 8.6 driver several times(uninstalled and reloaded per instructs) and still no luck. Oblivion doesn't run anymore and will not even complete a 3dMark06 test, (was showing 11 fps prior to lock-up). I don't get bsod or other error messages, just lock-up and after rebooting "VPU has recovered from serious error" for catalyst and the resolution is jacked. Grrrr
I haven't found anything on the Usual sites about unstabilities with the new driver. So, I think that maybe just a coincidence. 'sides, the problems seem to have started before that and may have just "pushed it over the edge". The comp still works fine for lite work (Internet, Acad, wp, ...)
Is there any further testing, or trouble shooting I should do before tossing it?
My comp: CPU: Intel E6600, MB: Asus p5b Deluxe, Ram: pqi 2GB ddr2, PSU Silverstone SST-ST50ef, VPU x1900gt(sapphire), OS: XP Pro SP2.
Thanks in advance for your time.
