Help me to draw concentric circles.
theMan
4,386
I need to print out a page that has concentric circles of a certain size. This is for a template so i can cut something out. (I am building something... :) ) Anyway, I need to find a program that will make this. I need the outer circle to be 152 mm and the inner to be 124 mm. (That's the size they should be when the document or image is printed). How can I do this?
peace.
montag451
4,587
Piece of string?
Or go into Word and draw a circle - use a ruler to measure it in relation to your scale?
Go into any graphics proggy,
make a new frame of the size of your smallest circle, make the circle fill your whole frame, make another frame, the size of your next biggest circle, do the same, cut/paste your smallest circle to this one etc etc.
Do a search for concentric circle software
lxskllr
59,192
9,681
I think I've got it for you :) Download Paint.net Use the ellipses tool, and hold shift while drawing your circle, to keep it round. It'll show you how big the circle is with the size counter. I didn't print it out for a test run, but I think this'll work out.
