Help me to choose a CPU: FX-6300 vs FX-8320 vs i5 4440
crashtech
10,573
2,145
Second option would be to get a Z87 motherboard(or wait for Z97) with Core i3 4130 or 4330, later upgrade to Core i7.
This is what I might do, but since I have noticed a lot of scoffing here at the idea of ever changing CPUs (c'mon guys, they are in a SOCKET, not soldered in!) I have stopped recommending such paths. But an i3 should retain good resale, so within a certain budget I think can make sense to buy a good mobo with a cheaper CPU with an eye on future upgrades. Yes.
TeknoBug
2,084
31
The problem is that I aren't just browsing the web and watching movies. Read my post again. It's true that much of the time I am using it for a general use, but I am also working with Photoshop/Bridge/Lightroom and gaming. And I don't want to be off very soon with the newer games.
Then yes absolutely go with the Intel route.
Headfoot
4,444
641
Preferably, you go with a i5-3xxx version. They can still overclock 400 mhz above their turbo boost I believe.
This is the best answer in the thread. Get the +4 multiplier overclock on the non-k model and you'll probably save a few bucks because 3rd gen is usually a littler cheaper than 4th, and it will be the fastest because it will give you some headroom while still being Intel quad
crashtech
10,573
2,145
...Ivy CPUs are on average a bit less expensive than their Haswell counterparts
About a $5 difference currently for comparable models, so unless you really want that 5-7% bump instead of the newer platform, it may not be much of a consideration.
Hacp
13,923
From what I understand, you can't even overclock up to turbo for haswell cpus. So overall, if you wish to overclock all four cores to 400mhz past turbo, it would be much more than a simple 5-7% bump.
TeknoBug
2,084
31
Yup my i5 3550 OC'd @ 3.9GHz or 4GHz/102.74BCLK.
Yuriman
5,530
141
On the other hand, there's no reason at all to get a (more expensive) Z-series chipset if OP goes with a Haswell i5, because they're fully locked. That cost difference can be put into a higher-clocked chip.
crashtech
10,573
2,145
Well, the Ivy starts with a an IPC disadvantage, which might be higher or lower depending on the app, but just for the sake of argument, it's safe to say 5-7%. Though that is small, the performance advantage of a 400Mhz increment is also not very large, so it become a significant part of the performance metric. Overall the gain is not large, nor a sure bet, and the price difference is also very small.
But I won't deny it is there, I just don't happen to think it's worth it to buy a new 1155 system at this point.
Gikaseixas
2,836
218
Fully agree. Like i've said on post 23, shoot for the highest clocked i5 Haswell
