Help me think of a prank
Coolone
983
Okay, so theres this person me and friends hate with a passion.
they leave their car unlocked all the time, so we want to do something to the car as a prank.
Here are the rules:
Cant cause any damage
should be moderatly easy to pull off (can be harder if its worth it)
I want this to be more annoying for them than anything else
rubenswm
1,871
Here are the rules:
uh. dead fish under seat?
iwearnosox
16,018
Go up to the car when it's on a slight incline, release the emergency brake and then quickly run and get under it. When the owner comes back he'll freak out when he sees your dead, lifeless corpse!
OMG that would be be funny! :p
Ryan
27,519
Easy, but some fox piss at a hunting shop and put it in their air vents on the outside of their vehicle. They'll wish they hadn't crossed paths with you evertime they turn their air on.
Spoooon
11,563
203
That's pretty good. I think a better one would be if the OP and some of his friends made a suicide pact and did it in the guy's car.
ajpa123
2,401
Just leave a bra or pair of panties on the backseat with a empty box of condoms somewhere near it.. lol
No mess, and will have this person wondering if anything really did happen.
Can't think of anything else that won't leave a mark
AJ.
Jmmsbnd007
3,286
Freeze a few cans of shaving cream in LN2, cut the cans open, put the frozen blocks inside his car and let them sit overnight. :D
IamElectro
1,470
Vaseline on the back of the steering wheel and shifter knob.
Thinnk about it do you check either of these.
Loggerman
822
Clean but hard to clean.
$5-10 of Puff wheat,leave windows down a couple inches.Some card board the with of windows(funnel),20-40 sec's to fill car.
BillGates
7,388
If it's sitting for long periods of time, put signs in the windows listing it for sale at a crazy cheap price. List person's cell phone number as contact. This works especially well at malls or other high traffic areas.
endo1234
11
Go to the junk yard, find a the same model of car that they have, preferably one in very poor condition and swap out the interiors.
Imagine getting in your car and realizing the seats are a different color, and smelly, as well as several other parts of the interior of the car.
It takes about 30 seconds to remove the backseat of a Honda accord, just 2 bolts. About 15 seconds to remove a front seat, about 10 seconds to remove the paneling around the radio.... You might need some practice for speed, but it doesn't cause damage, if you get caught the cop will believe that its just a prank cause you have duplicate parts. Watching somebody get in their house/car and then wondering if their in the wrong house/car is priceless. Getting spare parts will be a bit of a hassle, as well as learning how to quickly dismantle the car, but actually doing the prank will be quicker than you think.
Or you could just spray deer musk on everything.
Or poor raw eggs down the crack between the window and the door. Smells soo bad and is impossible to get out w/o dismantling the door.
Deflate the tires.
Go to a butcher shop, get all the spare guts he will give you, apply to car.
Put doggy doo doo underneath the handles/steering wheel. When he grabs it ewwwwww.......
Fill condoms with a little bit of mayonase, put in back seat. Drop a flier for hookers/"escorts" somewhere where his mom will find it.
Buy an HIV(or other STD) home testing kit, leave instruction booklet and "a how to live with a STD" booklet somewhere where girlfriend/mom will find it.
Put a voice activated recorder under his seat, see what you can find out. Leave audio cuts of your findings around the school.
Get to the fuse box in the car...... replace all fuses with blown ones. Leave good fuses in trunk/glovebox.
Get under the hood and disconnect the alternator or drain the battery.
Remove all the tires of car, leave on cinderblocks. I've seen this done in 30 seconds flat with 4 guys! Thats 1 minute for 2.
I'm bored u do some thinking now.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
unbolt the drivers seat... replace with milk crate
Connect horn wire directly to... your choice: turn signal (beep beep beep beep at the redlight), headlights, wipers (he won't figure it out until it's raining... and who wants to try to fix the problem in the rain ;) , radio (more work), etc.
Make a sign, hidden slightly attached under the trunk area that will trail behind the car once it's in motion... make the sign as offensive to some particular group of people as possible...
Get an airhorn... rig it with rubber bands and a small stick of wood so that when something is pulled, the airhorn is stuck on. It can be triggered by the door opening (mild shock), or attach it to the bottom of the car and about 20 feet of string to trigger it as it drives away...
Pam (the non-stick cooking spray) the inside window... be careful not to overspray on anything else - use cardboard or something to avoid getting any on any trim, etc. He'll think something oily condensed out of the air... (and it's a PITA to clean off)
Bullhorn in the trunk attached to cheap walkie-talkie... trail behind the car and say stuff which will be broadcast through the bullhorn and out the trunk... "Cops suck" "Hey you, the fat broad in the red dress" etc. Get people pissed at him.
bobcpg
951
Well i was over at my friends house during a party one time and i set it hosts file to forward his Google and Yahoo domains to a gay porn site.
About a month later after he found out i did that he jimmied my car open and poped my hood and wired my headlights to my horn. Man was that a good one. I was in a parking lot after a sunday softball game and turned my headlights on and my horn was a blaring and i didn't know what was wrong. And i have a loud horn!! He is a mechanic tho.
Bob.
DrPizza
Mar 5, 2001
49,601
167
111
Endo reminded me of the best one... If it has power windows, remove the fuse that controls the windows...
Then, take the door cover off, remove the pin that connects the inside door handle... disabling the inside handle.
After he gets in the car and drives somewhere, he won't be able to open the windows or open the door.. he'll be trapped in the car :)
Disable the horn to make it harder to summon help.
Just imagine him locked in his car, waving his arms and motioning like a mad-man...
Imagine the jokes for years to come... "locked himself in his car and couldn't get out..."
Best yet, pair this one with the sign joke... so he'll be locked in his car, yelling at people, with signs on the car saying "who wants me to kick their a$$ next?"
cypriot
362
Get lot's of crickets from a pet shop (they sell them alive as food for tarantulas) .. and dump them inside the car.. around 200 will do the work for around 10 bucks I guess..
ajpa123
2,401
Holy Crack Ho's !
You guyz get insanely creative after midnite.. i like it!
Keep em comin'
IEatChildren
750
I saw this one in a beer commercial and I laughed my ass off.
Fill the guy's car with ping-pong balls, or something similar. When he opens the door, they come pouring out. To make it even more fun, film his reaction when it happens.
DrPizza
Mar 5, 2001
49,601
167
111
slightly costly, and you have to be careful to not ruin the car...
cover the interior with plastic... including the ceiling...
basically, reverse shrink wrap the inside of the car with good quality plastic.
Then, get that great stuff foam... fill the interior with foam. It will conform to the shape of the car, and once it cures, is fairly strong stuff. I'd estimate about 40 cans
warning: if it eats through the plastic, or the plastic rips... there aren't solvents for removing that stuff once it hardens.
SirStev0
10,449
a friend and i once bought rats and mice and put them in another friends car
lets just say its quite a surprise to have a mice run up your leg will driveing down the road
Dufman
1,949
open the door, turn on the lights, close the door
= dead battery
simple, and it shoudnt cost them anything to jump it
