help me start up my dedicated MAME machine
5489
2,163
first question:
what do people usually use for a MAME computer. I have a 20" TV lying around that I would like to use. Can i use this on a dedicated MAME machine with a video out card? or does MAME run in DOS
iwearnosox
16,018
How about just using an xbox? There's a mame .iso floating around for it that's bootable, very cool.
Doodoo
1,423
Theres a dos command line version and a windows version. Mame32 i think...but i think its just a gui for the dos version.
aircooled
15,965
Anyone have a link to the iso? I did a quick search but found nothing.
hevnsnt
10,868
Originally posted by: 5489
first question:
My mame machine is a 1.4 t-bird.
as far as the TV goes... Sure.
Mame in dos: Yes, but use the front end Mamewah! :)
iwearnosox
16,018
suprnova is your friend. ;)
Slickone
6,120
first question:
Why not just use MAME32?
Also a TV would give you a more classic look than a pic on crisp monitor wouldn't it?
Though an LCD would be easier to mount and rotate.
jst0ney
2,629
too bad mame is in Japan or he would be glad to help you out. I am starting a mame project in December. I have an old p2 366mhz that I will be using for it with 256md ram running win2K. The machine dosen't have to be all that powerful so any old machine will work just fine. A small and quite machine will work good too. Check out the small form factor forum for ideas.
aircooled
15,965
I would like to build a stand alone arcade style mame box also. I just don't have the space for one at the moment.
Looks like the arcade style controllers are the most expensive item in the build.
minendo
35,560
22
Built mine into a Shuttle XPC and display it on my 32" Toshiba Flatscreen.
hevnsnt
10,868
Well I lost a LOT of my project notes.. But here is what I have..
Page 1
Page 2
Page 3 [Missing]
Page 4
Page 5 [Missing] Completed.. But you can get a pretty good idea from the other pages...
Slickone
6,120
Oh, I guess you all (and OP) are just talking about a PC to play MAME on, instead of an all out arcade MAME cabinent. BTW, there are many websites on how to build one from scratch or with an old cabinent, and several companies that sell pre-built cabs.
And while you don't need a fast PC to play the classics in MAME, to play any of the newer games, you'll probably need something faster than a 366. See
this.
Retrogames is a really good emulator site. I used be into emulators and read this site about every day. Unfortuntately I haven't had time in the last couple years to do anythign with them. The Vintage Gaming Network and aren't bad either.MAMEWorld. Build Your Own Arcade Controls site.
A pre-built cabinent company I haven't seen before. Check out the Mega cab. Wow!
