- Feb 11, 2005
- 399
- 0
- 76
Hey all, I'm gathering my equipment to setup a WC loop on the rig in my sig. I currently have, or plan to buy, the following items:
Swiftech Apogee XT CPU block
Swiftech MCW60 GPU block
Swiftech MCR220 2x120 Rad
Swiftech MCP350 pump
XSPC dual bayres for DDC pump
7/16" Tygon tubes
Bitspower 1/2" fittings
Feser One coolant
Scythe UltraKaze fans w/ Scythe Kaze Server controller
I already own the pump, radiator, fan controller, and GPU block. I'm thinking to run the loop like this: Pump/res -> Rad -> CPU -> GPU -> Pump
Now my question: Is the pump powerful enough for a loop like that? I've read that it can be voltmodded to increase output, would this be worth doing? Also, what about sticking a 1x120 radiator between the CPU and GPU? Good idea? I plan to OC the hell out of the CPU... not as concerned about the GPU, I'll OC it a bit, mostly I just wanted to get rid of that jet engine of a stock fan.
Thanks for advice!
7/16" Tygon tubes
Feser One coolant
Thanks for advice!
