Help me setup a networked Printer!!!
dguy6789
Hello you guys. Here is the deal.
I have two PCs. They are both connected through a router and can share files and see each other and such.
I have the following printer:
http://www.shopping.hp.com/webapp/shopp...bcat1=family&product_code=Q5765A%23ABA
It is connected to my primary PC via usb. I would like this printer to be able to receive and print documents sent to it via either of my PCs without me having to move the printer.
Bottom Line: How do I setup a printer connected to a pc that is on a network, to be able to be used by all PCs on the network?
Thanks in advance!
All you have to do is share the printer and give all the accounts on you machines access to it. (don't forget to install the printer drivers on the other machine.) And then add the printer on the machine using the add printer wizard.
