Help me setup 2 rpm-changeable 120mm fans that can be plugged into a wall
erikiksaz
5,486
I have absolutely no clue how to do this, so hopefully you guys can clue me in. Basically, i want to hook up 2, 120mm fans and be able to change their speeds. I'm thinking silent computer fans, but then the things might not run at the same voltage, blah blah blah. How can i do this and what parts are needed?
Heisenberg
10,621
Computer fans usually run on 12v DC. You'd need an AC to DC converter with a variable voltage from 5-12v. Then you could vary the voltage and hence the speed.
erikiksaz
5,486
Okay, i believe most of that could be found at radio shack. But, the problem is, how do i get that connected to the wall after it's converted and speed-changed?
AgaBoogaBoo
26,108
I'm not sure myself, but I'm rpetty sure the guys at the shack can help you out.
Heisenberg
10,621
The AC to DC converter plugs into the wall. If you can't find one with a variable output voltage, you could probably just stick a rheostat in there.
DOSfan
522
Oh sure.... Confuse him more! :p
erikiksaz
5,486
Suprisingly, i think i know what he's talking about. I had to buy a wall wart w/ variable voltage in the past for my headphone amp.
Thanks all!
Heisenberg
10,621
I do what I can. :D
M4H's suggestion would work too (aside from the gutting it part). Probably be cheaper also.
Jan 31, 2002
40,819
I do what I can. :D
What, not a fan* of carving up PSUs? (pun)
- M4H
Heisenberg
10,621
I do what I can. :D
- M4H
*groan*
Did you mean gutting the PSU for the fan, or using it to power the fans?
erikiksaz
5,486
I do what I can. :D
- M4H
*groan*
Using separate fans, while gutting out the possibly loud psu fan.
