Originally posted by: ddviper
Copied from BB.com forums. One of the better beginner training programs I've seen.
The body part split is as follows:
Day 1) Chest/Tris/Abs
Day 2) Back/Lats/Bis/Forearms
Day 3) Legs/Shoulders
Now for the exercises, and afterwards an explanation.
Monday: Chest/Tricep/Abs
Dumbbell Flat Bench Press: 3x12-10-8
Barbell Incline Bench Press: 3x12-10-8
Dumbbell Flat Flies: 2x15
Close-Grip Bench Press: 3x12-10-8
Skullcrushers: 3x12-10-8
Tricep Pushdowns: 2x15
Decline Sit-ups: 3x12
Cable Crunches: 3x12
Reverse Sit-ups: 3x12
Tuesday: Low-Intensity Cardio
Wednesday: Back/Lats/Biceps/Forearms
Deadlift:3x5
Barbell Row: 3x6
Chin-ups: 3x8
Wide-Grip Lat-Pulldowns: 3x12-10-8
Barbell Curls: 3x12-10-8
Preacher Curls: 3x12-10-8
Forearm Curls (Overhand Grip): 3x15
Forearm Curls (Underhand Grip): 3x15
Thursday: Low-Intensity Cardio
Friday: Shoulders/Legs
Military Press: 3x12-10-8
Behind the Neck Press: 3x12-10-8
Side-Laterals: 2x15
Squats: 3x12-10-8
Leg Press: 3x10
Seated Leg Curl: 3x12
Lying Leg Curl: 3x12
Standing Calf Raises: 3x15
Seated Calf Raises: 3x15
Saturday: Low-Intensity Cardio
Sunday: Low-Intensity Cardio
3x12-10-8 means 1 set of 12, then 10, then 8. That makes up 3 sets (hence the first number).
The reason for this rep scheme is to use a classic method of progression known as pyramiding. The set of 12 will be challenging for a weight to get 12 times, you would then raise the weight to whatever number you think would be challenging for 10 reps, then for the final set raise the weight to whatever would be challenging for 8 reps. The reps and volume are high for reasons mentioned above.
Number of warm-ups should reflect the weight you use. If you're benching 135 you need less warm-ups than somoene benching 405. Don't do excessive warm-ups, it'll waste time.
Light stretching should be done along with your warm-ups. Moderate stretching between sets.
Very important note here! All reps should be done with with a smooth, controlled negative. The negative should be done so that you have control over the BB/DB the entire time, without gravity doing much work. This will make the negative portion of the lift much slower than the positive.
Negative=Eccentric=Not Pushing/Pulling Part. Gravity helps.
Positive=Concentric=Pushing/Pulling Part. Fights against gravity.
If you're ever confused over which is the negative part refer to the above note.
The third exercise (if there is one) for each body part is all about higher volume than usual, and will lead to a "pump" a lot of the time. While the pump does nothing important, at the minimum it feeds the ego, which is important for bodybuilders to some extent.
Back work is done in lower volume because the form tends to get sacrificed at higher volume. This brings me to the next point.
FOCUS ON PERFECTING YOUR FORM OVER USING BIG WEIGHTS. You want bigger muscles you learn to lift with the muscle, not using bad form to finish a repetition. You find yourself cheating to get reps, then the weight is too high. Don't let your ego get in the way of your results. The big weights will come with time.
Muscles only need to be trained once a week to see good, solid results. Training them twice a week can lead to overtraining, and that is something nobody desires.
Cardio will keep you adding mass and staying leaner than without it.
Final point: calves and abs are just like any other muscle, you don't need to do them multiple times a week.
