Just got a new denon receiverthat supports 4k 60fps for when these movies finally exist. A friend gave me her old 5.0 speaker setup thats missing a surround which i will need to buy a new pair. Im in asia so its a chinese brand and the sound so far is ok with just the front and center hooked up. But I have the upgrade bug and hopefully can get some advice. I ordered a svs pb1000 as it was highly recommended.
So here are some questions
1. My avr is rated at 6-16ohm but the fronts are all 4 ohm. It seems that as long as I dont push the avr too hard this shouldnt be a problem. Dont know if thats correct?
2.Since the sub can handle all the lows really well and will most likely be overkill unless I want my neighbors to complain do i need high end towers?
Any thoughts appreciated
Im sure I have more questions but just cant think of them now
