Folks?I have been reviewing and trying to decide on a new PCI-e video card for a new system based on the following info below. I have read a lot and gotten some great advice from the folks here...looking to make the final decision.....
Compaq Presario - SR-1610-NX
MSI MB Socket 939 - Athlon Sempron 3200/1.8GHZ
1.2GB RAM
ATI Xpress 200 Onboard Video
Replacing stock 250W PSU with 430W PSU
I have decided to get one of the following ATI Radeon X800 GTO Cards. I am not worried about unlocking pipes, but am interested in overclocking on occasion (at east when running a game) and to help ensure I can get some time out of this card.
I am looking to load MS FLight Simulator, and then X-Plane eventually...and my brother assures me I must load Half Life as well, at some point....
I am looking for any suggestions you may have, so I can make the final decision, file the order and get on with my life
I know these run hot, so it is best to lean towards better cooling, if you can help it?while at the same time, my box is currently silent, and I would like to keep it that way as much as possible?.seems like any of the Sapphire models may start out cheaper, but I will likely upgrade the stock HS/Fan for added costs ("first through third thoughts" below)?Fourth thought seems to be what I am looking for with everything ready to go at once?My ideas on cooling:
Passive - (Sapphire Ultimate) nice if it will cool the card, but where does the heat go? Stays in the box, and I have to add another vent to make sure it gets evacuated
Stock - (Sapphire Regular)probably keeps the card cooler, but just pushed air around ()
FireBlade Cooler (Sapphire Fireblade)- It does evacuate air out the case, but the deign must be questionable with remarks coming back that it is invariably loud
HIS/AC ATI Silenser - (HIS/AC Card) Great reviews on being quiet; sends hot air out the back?helps cool the case somewhat as well?
Zalman vs Arctic Cooling Silencer - I like the idea that the hot air from the card is vented out the back (AC ATI Silencer) instead of just being further circulatred in the case, straining the other components; If I were to purchase an aftermarket HS/Fan, I am pretty sure I would go with the AC ATI Silencer, rather than the Zalman...
My First Thought: ($149 Now/$182 Later)
Sapphire ATI Radeon X800 GTO Ultimate - (Passive cooling now, upgrade the HS/Fan with either Arctic Cooling or Zalman etc. later if I find I need that extra cooling)
$149 - After Rebate at NewEgg - http://www.newegg.com/Product/Product.asp?item=N82E16814102628
If I end up replacing the Massive/Passive HS with an Arctic Cooling HS/Fan, that would add $33 and bring it up to $182 total w/o S&H
I think to get the best from this VPU, one needs to at least overclock it, and the passive HS/Fan just doesn't support that as well as it could be?.Maybe I could get the Ultimate, but then I would feel that I need to mount some fan over the card to help keep it kool?.then, I am still leaving the heat in the box!
Second Thought: ($143 Now/$176 Pretty quickly)
Get a Sapphire X800 GTO with the "Fireblade" cooling option for:
$143 AR fro NewEgg: http://www.newegg.com/Product/Product.asp?item=N82E16814102660
But I have read too many reviews that the fan is loud, and I would have to replace the fan with something better?I would rather have a quiet passive card, than a over-clocked loud card like this?
If I add a new HS/Fan Cooler for $33, price jumps to $176
Third Thought: ($139 Now/$172 Later)
Get the stock Sapphire X800 GTO; then upgrade, if needed to the AC VGA Silencer:
$139 AR from NewEgg: http://www.newegg.com/Product/Product.asp?item=N82E16814102602
If I end up replacing the stock HS/Fan with an Arctic Cooling HS/Fan, that would add $33 and bring it up to $172 total w/o S&H
Fourth Thought: ($165 Now/ $0 Later!) - Most Likely Candidate
So I am looking around and I run across the following card from HIS on New Egg; the HIS Hightech Radeon X800GTO IceQ II Turbo
$165 AR from NewEgg: http://www.newegg.com/Product/Product.asp?item=N82E16814161146
It has all the features of the X800 GTO that I was looking at with the Sapphire Cards?BUT THE AC ATI Silencer is already attached and ready to go!
The reviews are very good on NewEgg, indicating the low noice; as are other reviews I have found on both the card and the silenser separately
I appreciate any input or info I may not have considered?thanks for your feedback?.
1.2GB RAM
